Cannot ping between 2 servers (windows 2003 servers)
Hi there
Situration :-
Trying to join 1 server to domain but can't.
Details
1.Router - 192.168.0.1
2.Server 1 - 192.168.0.2 - PDC
3.Server 2 - 192.168.0.3 - workgroup
Checks
1.Can add client to Domain -> ok
2.Ping from client to PDC (reverse) -> ok
3.Ping from client to Router -> ok
4.Ping from PDC to router -> ok
5.Ping from Webserver to router -> ok
6.Checked system -> network cards -> working ok
But
1.Ping from PDC to Webserver (reverse) -> no
Using NetGear Wired Router DG834
Don't get it, why can't it ping ?
Any ideas most welcome.
Are you pinging by IP or name? If its the name then its a dns problem and you should get a host not found error. If its by IP is the subnet the same on all pc's?
Any firewalls installed ie MS firewall? If you do a tracert what happens
Faulty network adapter.
