Cannot get access to a particular page
Help please
I have two PC's, the first one is connected to broadband and the second networked to the first via a crossover cable.
For no apparent reason, my wife suddenly, after weeks of no problems, cannot get on to " Ebay " on the second computer though she can bring up every other page easily. The first PC loads Ebay straight away every time.
Nothing has been done to either computer. HuhHuhHuhHuhHuh?
I am totally non technical
Regards
Keith
I can only suggest clearing out the cache files from internet explorer. It may be calling up a corrupt file thinking its got the real one.
Right click on the explorer Icon on the desk top and sellect properties.
Use the buttons to clear files and cookies.
See if that helps.
Hi
Thanks for your reply.
I have cleared all cookies and files. I have downloaded "System Mechanic " and cleaned everything with that but it istill the same. Huh
In Tools -> Internet Options -> Connections.
Click the "Lan settings" button, and make sure "Autuo-detect" is disabled.
We are now on the 4th post from yourself on this very subject.
Please do not post this accross multiple forums, as it can bee seen by all regardless.
Two others have been removed.
Hi
I went into "Lan settings" but there wasn't any auto-detectHuh?Huh
