Can't send Emails
Can't send Emails
I use incredimail to send emails but since installing McAfee on my computor I am unable to send anything. If the 'My server requires Authenticating' box is ticked the system says my authentication information is wrong, if I untick it it sends mail out of my outbox but then it dissapears into cyberspace. The same problem with outlook. Can anyone help me :?:
1 REPLY
Can't send Emails
Mcafee is the problem. If you check your setting in you email client you should find it doesn't actually have the correct settings they will be set to something like 127.0.0.0 for the mail server.
What Mcafee does like must AV is lets you send the mail to the AV program instead of the real server this should then scan it and pass it on.
So the fault will be the mail client not having the correct ip etc or mcafee setting for mail is wrong.
If you change your email client to the correct plus net address it wont be scanned by AV.
So somewhere in mcafee(you dont say which version so cant help) it will have the wrong mail settings
