Can't Exit Safe Mode
Hey I was trying to find some help on the net as to what to do about my
problem. Don't know if you can help or not......When I boot up my
computer, it won't boot into anything but safe mode, even if I F8 at begining
and select normal it stil decides to boot up into safe mode. Do you have any suggestions? Cry
Are you shutting down correctly.
In some cases, the boot manu can come up twice, with the second one not displaying correctly.
Have you installed any software, hardware or updated any drivers lately?
It has been in safe mode now for about 3 days continuosly. The only thing that i can think of is that i recently installed some windows updates, but that was fine for a few days until safe mode came on.
I tried to to a restore point to when the computer was fine but even when it completed that, it stil booted up in safe mode.
I running ME btw :shock:
that would be your problem.. ME.. the WORST OS from MS.. if you can .. find your self a 98SE CD that you may have once had, or get your self a copy of XP home or Pro depending on your needs... just cut your losses.. ME is BAD
even MS dont like it Cheesy
would that delete everything from my hard drive though?
ME => XP you can upgrade.. so you wont loose any data and most app's will not need reinstalling
ME =>98SE is a downgrade so you would have to format your PC and thus loosing all your data :S however you could back said data up using a network or CD's?
andy
