Can anyone help me...PLEASE!! Wireless modem/router
I have a wireless router/modem I also have a wireless card.
Now I can ping the router and acess the set up of the router from the routers IP address using internet explorer.
The router/modem is connected to plusnet.
But I can get a web page or access my e-mail! I have turned off firewalls and still no luck.
Anyone have any ideas? My modem.router is this one...
http://www.digidave.co.uk/product_info.php?products_id=182&osCsid=cae95d3c1e8974275a199b227f7e2929
and wireless card is the fujitsu siemans connect 2 air wireless lan
Any help would be greatly appresiated!
have you turned wireless on, on the router as mostly it isn't enabled by default.
Good point and I ahve had a look but the only theng I can find is enable AP which is ticked...so looks like it is on.
hmm ok, is there a part where you input your username and password..is there a router status that tells if it's connected, if so how long for etc.
Yes, on the router and the wireless card.
Both say connected and with a time.
Also, the wireless card utility says the stregth of signal is excellent....
the mystery continues...
ok, have you tried doing the network wizard, and internet explorer connection wizard? D you have msn if so add me, sales@richpixel.co.uk
Sorry, dont have msn, perhaps I should get it.
I have tried the wizard but not sure what choices I sould make?
get msn and add me as i'm about to be banned from the forums..lol
Start again
Can you logon to the router setup via wireless?
can you ping the router via wireless?
can you ping 194.119.131.66 via wireless?
can you ping www.plus.net via wireless?
type ipconfig /all and post the results.
What error messages do you get?
cann anything get out IE Windows update av update?
Is there any firewall setting on the router or security were you have to enter your MAC address.
Does it work via ethernet?
If you can answer these question we will have a better idea how to help
