Can I ue my Bluetooth mobile headset with my laptop ?
shermans
I have a Bluetooth mobile linked to a Bluetooth headset. I would like to use the same headset with my laptop to make VOIP calls and to use Skype. Is this possible ?
The laptop and the headset pair with one another quite happily. I have tried to change the audio and microphone settings in Control Panel>Sounds but there is no option for the Bluetooth headset. It occurs to me that I might need some special communications software.
Can anyone tell me whether I am barking up the wrong tree ?
What usb blue tooth device are you using? I have a MSI and it provideds software to do what you need. Its down to the software to know what devices are connected and how it can use them.
shermans
Thanks for the help. I found this site on Google which seems to answer everything and is worth looking at if anyone else is interested in doing this.
http://www.windowsdevcenter.com/pub/a/windows/2005/07/05/bluetooth.html
Good grief...... been using a Bluetooth headset for ages,glad I don't have a Windows machine if you have to go to all that trouble Tongue :twisted:
