CD Writing SHAREWare?
Stew
I need some software that will let me Burn an CD iso image - a feature that Windows XP doesn't offer.
Can anyone recommend some free/shareware that would do the job?
Cheers,
Stew
1 REPLY
holdtight
Hi Stew
There is a plugin for the windows burning tool as part of the power tools called iso recorder it does work but its still not that great as it doesnt give you many options
do a google search for iso buster or deepburner both are free, sorry i havnt got time to locate the links for you as im just on my way out
you could also try www.download.com and search for iso you will find a free tool there
Just had time to find this for you hope it helps
Bill.
