C$ share
zpeterk
C$ share
Is there a way to stop the C$ share
C$ share
Create a batch file (i.e. cshare.bat with the following line in it
net share C$ /d
and add it to your startup folder.
See if that does the trick - I don't actually know what it is though so have no idea what impact there is in removing this.
Method originally a VB6 code snippet here.
A search of google groups for 'C$ share' found loads of links to do what you are asking. The following links may explain a permanent method to stop it appearing:
User cannot access C$ share.
How To disable NT Servers' default C$ share
C$ share
Yes it does work, I run this on my PC at work, although Im not 100% sure if the syntax is right.
You need to also add admin$ into it and same for any other partitions you have.
Chris
