Buffer Overrun Detected?!?
Midville
When I try and run Adobe Elements 3 (Photo viewer), I get this message. I have to close the programme down.
Microsoft Visual C++ Runtime Library
Buffer overrun detected!
Program -- Elements 3
Can anyone help me out, I have run AV and Windows defender.
Thanks in advance.
Njal
Memory problem? First try closing any other open applications.
If no success try changing:
Preferences: Memory & Image cache
Cache levels : 4
Maximum used by PSE: x %
I think x % is 50% by default (I don't have PSE on this PC so I may be talking rubbish!). Try increasing x to a max of 80% in 10% increments.
Regards
Neil
Midville
Neil,
how do I go about changing this is it in control panel?
Thanks in advance
Njal
No, I think it's in PSE - Preferences - in the menu system.
I haven't got a copy here at work so I can't look. Have a look in PSE help file if you can't find it.
Sudden thought - this may only be in PS CS2, I don't know if it's available in Elements. Sorry, trying to work from memory here (which has been addled by too much beer over the years).
Regards
Neil
