Broadband to PC to Laptop
Thegreatest
Done
Do a web search on "Internet connection sharing" or "ICS".
on the pc with the modem start/run then type cmd when the window opens type ipconfig /all you will get somehing like this
IP Address. . . . . . . . . . . . : 10.0.0.10
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 10.0.0.2
DNS Servers . . . . . . . . . . . : 212.159.13.49
212.159.13.50
10.0.0.2
194.119.131.65
what ever the ip address is(10.0.0.10 in this case) go to the other pc and edit the tcip setting and set the default gateway to the ip of the other pc and you should be away(you will need to set the dns if its not set)
shermans
Get a wireless router - costs are less than £40 these days and then you will have complete flexibility.
