Bootable CD
Fixes: 133
Bootable CD
I need to upgrade the firmware for my NEC DVD RW drive.
All attempts to use the supplied Windows Upgrade program even in Safe Mode causes the PC to crash so I have been advised by NEC to use the DOS program.
Unfortunately my system does not have a flopyy drive and no instructions have been given on how to do this from a CD.
Can anyone offer a solution, please.
Cheers
Forum Moderator and Customer
Bootable CD
What version of Windows are you using?
Try booting off the windows install CD and get to the recovery console (don't do a repair install). From there you should be able to run any DOS based firmware apps on the hard disk.
Have you tried running the upgrade from a DOS box?
Fixes: 133
Bootable CD
Hi
Thanks for the reply.
I should have said I am running XP Home.
I'll try your suggestions and get back.
Cheers.
Denzil
Bootable CD
Many recent motherboards can boot from a USB memory stick, if you have one.
