Bluetooth Printing - Help!!
mossgrove
Does anyone know if it possible to buy USB Bluetooth adaptors which will work directly into a printer? I have two Canon printers S330 and Selphy 510 both of which are USB only. I would like to be able to site them remotely from the PC without cables (in the same room).
Failing Bluetooth anyother ideas how to achieve the same result? I have a LAN running on a Netgear DG834G router
