Blue screen of death due to voyager usb driver
Anybody else get this, i think i have the latest driver but need to check.
is it an Athlon dual core issue or do i have a duff modem, sometimes get phone line noise when the modem is running?
Would a change of modem help?
What OS are you running?
Have you tried uninstalling / reinstalling the drivers?
Fully patched and updated Xp home. Have downloaded latest driver from Bt site. Do i need to uninstal previous version or just install over the top,their instalation guide is not working on line.
should say that it has happend eversince install, but has started to happen more frequently in the last two weeks
I always recommnd uninstalling any previous drivers.
Also try a reinstall with the drivers that came with the modem if the new one still causes a problem.
