Best performance (Want to experiment)
I have been reading many websites since my new build about optimal settings and oveclocking. Is there a really good easy to understand website that helps to set things up for best performance in the bios and also for CPU and graphics cards. Most settings in the bios are set on auto.
My spec is:
Asus A8N-SLI Deluxe S939 NF4 SLI ATX - Sound 2xgln 1394 USB2 SATA
AMD (Venice) Athlon 64Bit 3000+ Socket 939pin 512k L2cache 90nm
2 x Corsair (VS512MB400) 512MB, DDR400 / PC3200, non-ECC, 184 DIMM, unbuffered, CL2.5, 32Mx8 DRAMs,
Seagate ST3120022A 120GB 7200RPM UDMA/100 2MB Cache - OEM
PNY Verto GeForce 6 6600GT PCI-E 128MB GDDR3 (G66600GN1F12XPB)
Fixes: 57
I assume you looked at my response to the thread on overclocking a couple down.
The link in that will answer most of your questions
Found it couldn't connect to the website until now?
Fixes: 57
Can you connect now as the link works for me
This guide is for DFi motherboards, but a lot of the information is overclocking Athlon 64 and RAM in general and there is certainly a lot of information Smiley
get a cup of coffee for this one
http://www.dfi-street.com/forum/showthread.php?t=20823
I see you have an ASUS motherboard, Venice CPU, Corsair memory and a 6600GT.
These should overclock quite well, especially the Venice and the 6600GT.
This review suggests you should be able to get about 240Mhz out of your memory instead of 200Mhz. http://www.amdzone.com/modules.php?op=modload&name=Sections&file=index&req=printpage&artid=181
