Benchmark Software
Midville
Benchmark Software
Just wondering if there are any 'free..ish' programmes which will inform you how you system is performing. Or any prog that you would suggest.
Many thanks
Benchmark Software
Google is your best mate sometimes, it really is
http://www.google.co.uk/search?hl=en&q=free+benchmark+software&meta=
I think (think) Futuremark has a free version, alot of people seem to like that one
http://www.futuremark.com/products/
Benchmark Software
I aggree with the above, Futuremark 3DMark is probably the best
Try 3Dmark05 for overall benchmark (mainly graphics intensive)
Try 3Dmark01 for overall benchmark (mainly cpu intensive)
Both are free
Midville
Benchmark Software
Thanks the furturemark seems good, not sure what my score means.
What is a good score Cheesy ?
Benchmark Software
With Futuremark you can use their ORB (online results browser) Just need to register i think. When you have run a test you can submit the score, from there you can setup you own ORB Cool
For your system you should be looking around 2000-2500 point mark in 3DMARK 05 at a guess!
When running 3DMark - turn off all programs i.e msn, web browser. Go into your graphics settings and make sure you dont have any AA / AF or VerticalSync on. Doing it this way will give you a more true system benchmark.
Have fun, and if overclocking your 9800pro, go easy on it!!
Midville
Benchmark Software
Thanks Paco..... not overclockering because it works fine for me on HL2 and Office, just curious really. Thanks again
pc
PCPITSTOP.CO.UK THIS IS GOOD TO CHECK YOUR SYSTEM HAVE A LOOK
Benchmark Software
Has everyone here forgotten SiSoft Sandra ?
http://www.sisoftware.net/
Shame on you Wink
Benchmark Software
There are a ton of benchmarks for specific hardware.
Such as Super Pi for Memory
Hd Tach for Hard Drives
FutureMark 3Dmarks are now mainly GPU based where as the 3DMark01 is often seen as a whole computer hardware benchmark.
Aquamark was a good one, but sadly its gone now
CD/DVD Tach the name says it all
You also have Lavalys Everest that monitors temperatures, gives alot of info on your PC spec and also has a couple of memory benchmarks
Thats all the ones I have used.
Midville
Benchmark Software
Cheers Phearfactor, quite a good list for all to view and use. Thanks to everyone. Smiley
mike001
Benchmark Software
http://download.guru3d.com/aquamark3/
