Becoming Pingable
Becoming Pingable
Everytime i goto ping a website in dos my sygate firewall says allow or block or i could allow it through all the time, i just let it through when i ping just incase anything comes through with it if i allow it through all the time without asking, My question is would it be SAFE to allow it through all the time.?
Thanks...
Becoming Pingable
Yes.
Becoming Pingable
I have just upgraded to 1mb. I was doing a speed test via one of the sites mentioned in MTU tweeks. However I got the result that I was not "pingable". I use Agnitum Outpost free firewall (no support) - Can anyone tell me what settings I need to change to allow this function to work?
Becoming Pingable
Are you using a router? If so it is probably blocked on there (most have ping from outside disabled).
Don't know outlook so can't help with it's settings.
Becoming Pingable
I thought most security sites tell you not to become pingable, it doesn't directly pose any danager, but it means your more visable on the internet.
Becoming Pingable
Yes, I do run through an origo router, and if being "pingable" is no big deal I'll leave it as it is as it all works fine. Thanks for your input.
