BT master phone socket wires - how connect?
henderson1977
Hi all
I have recenty moved home and noticed my BT master phone socket was missing the 2 screws to secure it in place. Consequently, the internal wiring that was keeping it secure has eventually come loose and my phone line no longer works.
I obviously need to re-connect the 2 wires and screw the box securely. I now have 2 screws, but I am not sure where the 2 internal wires should connect to. There are several options, but I want to avoid trial-and-error, in case I permanently damage anything.
Can anyone advice how/where the 2 internal wires should be connected to on a BT master phone socket please?
Apologies if this post is off topic and not regarded as "hardware"...
Thanks in advance
Scott
If the rest of the wiring is conforming, then 2 and 5 should be connected.
henderson1977
Thanks for your swift reply, gotdsl. Sorry but I am a complete novice at this... any chance you could either explain where 2 and 5 are, or provide a link to a diagram please...?
Cheers
Scott
Moderators note by John (johnessex) Full quote of preceding post removed as per the Link:rules
Njal
henderson1977
Thanks both, I'll give it a go.
Nick_Russell
henderson1977
Thanks guys. I go it working again ("with a little help from my friends").
It would have been better to have the correct tool to secure the 2 cables in place, but I don't expect it to come undone.
Scott
Njal
It's amazing what you can do with a large enough hammer!
Regards
Neil
The_10th
Pin 3 is for the Bell voltage usually orange.
