Avatar help and explanation
I would like to place a "pretty picture" in my profile, but am unsure how to do so.
I've tried searching both this site and Google for help, but no luck. So many sharp surfers here, can some kind person help, or point me to a useful url?
TIA
michaelscott
You need to click on the 'Profile' link at the top of the page, At the bottom of that page u will see a box to link to an off site avatar - u'll need to upload a suitable image to some webspace and enter its address, eg http://www.towill.plus.com/avatar.gif
you upload a picture to your web space and then make a url link to it from the profile options. eg mine is located in htdocs/pics/Scotland60.gif but you dont need the htdocs in the url so it would be:
http://www.yourusername.plus.com/pics/Scotland60.gif
Unvalued customer since 2001 funding cheap internet for others / DSL/Fibre house move 24 month regrade from 8th May 2017
Also note there is a limit on the image viewable size and file size. I believe this is a max of 80x80 pixels (widthxhight) and 6k for filesize. You may need to adjust the image to fit these parameters using a graphics package.
The dimensions are right, however there is a slightly larger limit of 10kb
The max filesize is 10k (most forums are 6k by default).
Edit: Gah, beaten!
I am trying this feature out but I get a red cross in the image preview on my profile?
chris :?:
are you sure that the url below is correct for your picture?
http://www.chandler100.plus.com/ll/largerlout3.gif
if I try that url I get page not found.
It helps if I can spell............ Shockedops:
Thanks for the pointer
Chris Shockedops:
