Auto Shutdown?
Auto Shutdown?
Is there anyway to tell your computer to shutdown at a certain time?
This computer connects to the net with an internal modem, then i connect it to a hub, then connect everything else to that, and everything else is on a different floor, so it's a hassle to turn it off at night.
Is there a way for me to tell my computer to shutdown at midnight every night?
Auto Shutdown?
There are lots of programmes available to do this. Some Freeware, most shareware.
Typing in "Shutdown Timer" in a search engine will bring up loads.
Auto Shutdown?
I have just done this myself, and is excelent to work from windows scheduler.
The best link I found was THIS ONE
It provides methods for NT, XP, 9*, the works (windows based).
The more important points are the schedual settings.
Make sure you set it only to run when the computer has been idle for X mins. Otherwise it may shutdown just when you don't want it to.
