Audio Issue
Fixes: 132
Audio Issue
I am sure I have seen a related thread before somewhere but cannot find it.
Basically, when the audio (movie or mp3, etc) reaches a loud section it distorts or even begins to break up. Then, after about 1 or 2 seconds the audio appears to be automatically reduced.
The level rises again during the quiet parts causing further problems again during the louder ones.
I am running XP (SP2)with 1GB RAM, plenty of free HDD space and a Sound Blaster Audigy card with latest drivers.
Perhaps there is some setting I need to turn on/off?
Any help, please?
Forum Moderator and Customer
Fixes: 57
Audio Issue
Have a look at Dynamic Range Compression about 2/3rds down this page http://www.techspot.com/tweaks/soundcard/sound15.shtml
Fixes: 132
Audio Issue
Thanks for the link.
Unfortunately, Dynamic Range Compression applies only to the Audigy 2 cards which I don't have.
I have reduced the volume slider from 86% to 71% as suggested - have't tested it out as yet.
Fixes: 132
Audio Issue
