Asus P5B and Raid
Asus P5B and Raid
Just managed, in my old age and lacking pennies , to buy an Asus P5B motherboard and Intel Core 2 Duo 2.4 but i'm confused - how do i configure raid 0 there are 5 sata sockets on the motherboard - sata raid, sata 1,2,3,and 4 which one's do i use as the manual is most confusing.
Regards
John Sad
Asus P5B and Raid
As far as I know you need to use the SATA_RAID port to enable the RAID menu in the BIOS. I believe it allows you to use RAID on just one drive if you want.
How you go about getting more than 1 sata drive in RAID with only 1 port, I do not know.
I guess you set it all up in the BIOS then this allows you to use the standard SATA ports as SATA RAID ports. But I think this will make the SATA_RAID port labelled in the manual redundant. Although you should email ASUS and ask for some clarification unless someone on here knows.
Asus P5B and Raid
To enable RAID 0 on a bootable array, connect 2 drives (ideally a matched pair) to SATA channels 0 & 1. start your machine. Enter the SATA BIOS and select RAID 0 (Striping) for those 2 drives. You will then need a floppy disc containg the RAID drivers and press F6 during windows setup (when prompted) to load the drivers so that windows can recognise the controller.
hope this helps
Regards
