Asus A8N-E Drivers XP Home
could anyone help me i need to know all the drivers for my m/b .
chipset driver
bios version 1013
having trouble with internet got a netgeardg834 v2 it could be the drivers HuhHuhHuhHuhHuhHuhHuh??
Moderators note by John (johnessex) All capitals title changed to lower case as per the Link:rules
Alecto
Here is the asus site with all the stuff on. Why do you think it's the mobo driver?
Have you got the latest firmware for the router ? It's V3.01.25 - other versions are not so stable. I'd reset the router and reload the firmware (from the netgear site if you've not got it stored) before doing anything else.
If you can access the router with your current configuration it is highly unlikely there is a problem with the drivers or the BIOS version.
As Geoff said, it is most likely a problem with the firmware on the router.
http://kbserver.netgear.com/release_notes/D102765.asp
