Anyone recognise this clip?
I found it loose in my computer. It looks like a heatsink clip, but I can't find where it belongs. So get those sides off, guys, and help me out!
Here's a picture: http://img86.exs.cx/img86/3148/b0jp1010003.jpg
Click the bottom right to magnify.
I have seen these, or similar come, off the heat sink on a graphics card.
I take it you have checked that.
Good pic.
Mark
Or possibly Northbridge heatsink :?:
pcsni, I will take the graphics card out am. to check, thanks.
barsteward, that was my first thought as the heatsink on the Northbridge was loose, but I can't see how it will fit. Would there be only the one?
Yep - mine has
barstewards
Yes it is off the Northbridge, thanks. Difficult to get a close look, but with a strong light I can see one of the anchor pins has pulled out. Unless I can get a clip with a mirror image, I will have to glue the heatsink on.
