Anyone implemented phpbb on a LAN?
I've got access to a development server on our network and we have been talking about setting up a local discussion forum for staff. Just wondered if anyone has done this before and what was needed.
It runs IIS at the moment and I can install either mysql or sql server on it. I've got the most recent version of ActivePerl to put on.
Any thoughts appreciated.
just install mysql, download PHPBB from the site, install PHP first, then just extract all the phpbb files into ur IIS www directory, and browse to it, you will then be able to run the online set up and you should be good to go
buz
I use xampp and have no problems with it. It's also easy to set up.
