Anyone had problems with latest version of msn messenger 8
Hello
Could someone help me I had just downloaded the latest version of
msn messenger version 8 windows live and it pauses out when I try
to run it and cant do anything else and have to end the program in
windows task manager I am just wondering of anyone else has
experienced this problem and if so what they did to rectify this
any help would be a great help.
Many Thanks
seems like there are a few probs as it is a beta version. See link
http://forums.microsoft.com/MSDN/ShowPost.aspx?PostID=317244&SiteID=1&PageID=1
Midville
I havent had any problems with it so far, however there has been a recent update to the beta which I downloaded a few days ago.
I think I have an old version of a beta flying about if you want it ?
I have migrated from MSN to Trillian anyway. Functions better for me and works better all in all.
I have never had a problem with any of the betas of WLM 8, is it the branches version you are using(not sure if thats ones still on private beta) go to help and about to find out
