Anybody using SMC Barricade 7404BRA Router?
Are you having any trouble getting logged on secure sites on PlusNet if not would you mind listing your router settings and browser etc. 90% of the time I am not getting logged on and outpost reports - remote port 520 - Reject connection To port opened by system. This still happens when outpost is disabled and I am sure it is to do with the router firewall I am using firmware 0.24
Neondaze
Am using the self same modem/router. Have been for the past 2 weeks. Configured it 'straight out' of the box. Works fine. Since then the only advanced setting I used was to turn firewall on.
I am using runtime version 0.20
i use the SMC7404BRA and have no problems connecting to secure plusnet pages with the router firewall enabled. you might try flashing to the latest version of the firmware if you haven't already.
cheers
eric
