Anybody got recommendations for good Registry Cleaning Tool.
My system is getting noticeably slower and in the past I've just backed-up, formatted and started from scratch. Trouble is that there's always been something that got forgotten or lost no matter how much time I spent planning it.
Has anybody succesfully 'refreshed' a system with a registry cleaner? Any good/bad experiences?
Ashampoo Winoptimizer will get rid of most redundant files
from your drive and registry, have a go with the trial
version. As I use it regularly I can't say if my system
feels refreshed, but I haven't re-formatted for quite a while
and haven't noticed any slowdown.
Alec
There are loads of these about now.
http://www.pcbugdoctor.com/
is a good one and you can try it free.
There is the free MS one regclean
http://download.com.com/3000-2094-881470.html?tag=list
Other more expensive tools like Norton and Vcom all do a good job. The real answer is to create a clean system with all you software loaded and then use ghost or truimage to create a image. Then every x Months role back with the image it only takes 10-15mins and is just as quick as messing with the reg.
The new Trueimage does a image while you work on your pc so you loose no productivite
robstreats
RegSeeker is Freeware and very good (makes backups) Get it from:-http://www.hoverdesk.net/freeware.htm
Thanks all - now trying various options out.
