Any Firebox experts out there ???
Hi All Sad
We have replaced a Firebox X5 edge with an X700 Core with Fireware Pro. The edge worked fine with the following IP scheme (changed slightly!):
84.92.120.120 : Gateway address (set as gateway)
84.92.120.121 : ADSL Router (routing..)
84.92.120.122 : Firebox (orig x5 + now x700)
84.92.120.123 : Broadcast
Mask = 255.255.255.252 (/30)
I'm using the same external IP address on the X700 as with the previous X5 (84.92.120.122) but the X700 will not allow me to set the correct netmask of /30 - it insists on /24 so lots of ip addresses are not routing correctly in/out - the X5 was quite happy with this! The x700 says 'the default gateway you entered is a network address. please enter a valid ip address" - is there anything i can do to correct this (by the way i tested another site with an x1000 and this did the same!)
any help really appreciated as this is becoming a problem. many thanks!!!!
