All-in-ones
Rourkefamily
All-in-ones
Thinking of buying one of these. Someone put me on to a Lexmark on sale for less than £50.
Anyone on here go one? What are they like? Recommeded brands and are the cheap ones any good? Or am I better of with a dedicated Ink Jet?
All-in-ones
Check out the ink costs first.
You may find that a replacement ink is more than £50
Chilly
All-in-ones
The cheaper end of the Lexmark range is not up to much really.
The genuine cartridges are expensive and alternative ones are not that reliable.
There is a Cartridge World near me that will refill a Lexmark cartridge, but they make no promises about it working or not.
It's usually cheaper to buy a new Lexmark than replace the cartridges.
I have an HP 1215 three in one and rate it highly, I seem to remember it was about £68.00
Rourkefamily
All-in-ones
Thanks Paul.
I can pick this up on the web for £55 plus delivery Smiley
What about the replacement cartridges. Any recommendations?
All-in-ones
To be honest I use the scanner most and have yet to replace the cartridges.
I do not know it the supplied cartridges are demo, and as such 100% full or not
My printing needs are fairly modest. I have seen plenty of cheap replacements about, but as yet cannot recommend any.
All-in-ones
I echo Paul's comments about the lexmark, I had one thrown in free with a computer I brought last year and while the quality of the prints hasn't been too bad, the cost of replacement ink is expensive.
Since you can pick up a brand new lexmark for silly money, strangely it seems cheaper to buy a whole printer with new ink, than to purchase replacement ink.
Wonders will never cease.......
Rourkefamily
All-in-ones
Order placed for a HP 1215. £60.94 delivered.
Thanks folks. Cheesy
All-in-ones
ditto on those costs, I own a lexmark 6150 all in one, and the ink is real expensive, costs me around 48 quid to replace both of them, luckily, they never run out at the same time lol!!
All-in-ones
Here's hoping you are happy with it, dont forget you will need to buy a USB cable.
Rourkefamily
All-in-ones
Think I am OK. Is this the cable with USB one end and a smaller plug at the other end? Is so I have got a spare one..
