Access to Firewall log on Voyager 205?
Having given up on the Draytek (see other thread!) Im going with the Voyager 205's built in firewall.
I've gone to Advanced ~ IP Settings and setting up the rules seems easy enough (10 out of 10 for the excellent help page!). I can also enable logging for each rule (and set log options), and the help page suggests that I can view these logs but doesn't say how. It was late but I can't find anywhere on the Web UI menu to do this.
google is my friend and I discover ...
The Voyager 205 has a telnet interface (called the CLI - Command Line Interface). Having a poke through this it seems to be possible to redirect trace (log?) messages to email, trace, both, or none (can't remember the command just now). However, I can't find any way of actually viewing the trace. I can retrieve various trace config settings etc.
Oh - the CLI command set is very cool. Assuming all commands are supported this is a beast of a modem Wink
The CLI command set looks suspeciously like the one from an old SolWise box I had once. A SolWise 135 I think ....
Any ideas how I can view the modem logs?
Cheers,
Andy
