ATAPI DVD-ROM
ATAPI DVD-ROM
Hi techie's.My ATAPI DVD-ROM isn't working.In device manager it s asays the device is not enabled.When i click enable i am told windows cannot enable this device.I have checked all connections and all ok.I recently installed xp service pack 2.Don't know if this is the reason.Come on guys, i know you can help.
Regards
Bob
ATAPI DVD-ROM
Try removing it from device manager then rebooting.
XP should detect it on reload and install it.
If it doesn't, carefully remove it and place in a suitable waste receptacle, then replace with a nice new DVDR/W, circa £35 at a store near you.
ATAPI DVD-ROM
also check the bios settings to see if picking the drive up correctly
ATAPI DVD-ROM
Many thank's,Tony,it worked a treat.
