AMD barton xp3000+
AMD barton xp3000+
iv just upgraded my cpu to a AMD xp3000+ barton FSB333 MHZ but could any one tell me why it only shows it as a AMD xp2500+ .
if i change the FSB to 400MHZ it now shows it as a AMD xp3200+
i am only running DDR266x 512mb which is slow has the speed of my memory got somthing to do with it.
i am at the moment waiting for DDR400x1gb to turn up
can some one help :?
AMD barton xp3000+
Yes, you should be running PC-2700 (DDR333) RAM for the 333 FSB Processor. to operate synchronously with the memory.
AMD barton xp3000+
does that mean that the memory that iv ordered (1024 MB (1GB) PC3200 ddr400) will be to fast for my cpu or i just will not get the full use of the memory
:idea:
the_norris
AMD barton xp3000+
You RAM should run by default at the speed of your CPU. Eg 333 Unless you go into the realm of overclocking.
AMD barton xp3000+
ok thanks
now all i got to do is play the games at full speed :lol:
