A360 dynamode
A360 dynamode
I recently got the usb broadand modem when i got plus.net broadband suscription - ive got redhat on my computer and it didnt recognise the modem ... so i mailes dynamode and they sent me the drivers ... a .c and .h file. i tried using gcc *.c to compile it put it came up with a whole load of error messages! can any one help me / give me some tipes on how i should be going about installing these drivers ?
assume that i am a newbie to linux!!!
thanks
marc
A360 dynamode
The follwing link is where i have put up the drivers files online permenantly for anyone who would like to download them!
http://www.scrimshire.8m.com/1_multipart_xF8FF_2_461B%20linux_usb.zip
thanks for your time and help!
A360 dynamode
as that hasnt worked - anyone who would like me to mail them the driver , drop me a line at marc.scrimshire@westminster.org.uk and i will be happy to mail it to them!
Ianwild
A360 dynamode
I'm just looking now - I think it is the space in the URL - That is invalid. Does the URL have a space in it?
Even putting "%20" doesn't work. Have you considered putting your files on your PlusNet Webspace - It looks vastly more flexible than freeservers!
Regards,
A360 dynamode
ill put it up now !
A360 dynamode
permisiion denied -550
just send me a mail - marc.scrimshire@westminster.org.uk ... and i will forward you the files. they arnt large at all!
Ianwild
A360 dynamode
Have you tried uploaded them to the /HTDOCS directory?
You can't put files in the default directory when using FTP...
Regards,
A360 dynamode
i ve uploaded it - the file is called a3600linuxusb.zip .... i dont know what the adress will be though ... something like scrimshire.plus.net/.../a3600linuxusb.zip
ill be online later,
thanks.
Ianwild
A360 dynamode
gosforth
A360 dynamode
Dear Ian,
I have tried to download the file from the address you quote. However, when I try and unzip it I get an error message "error missing 1 byte is zip file, process anyway" then it says the file is not a valid archive.
I would be very pleased if you could send me the files. I contacted Dynamode back in January, but they never bothered to reply.
Chris
A360 dynamode
that was the problem i had whith dynamode. they just won't pick up the phone on the help line either. if you want I can forward you the mail which dynamode sent me. i would be very pleased if someone could work out how to install these Drivers!!
drop me a line at: marc.scrimshire@Westminster.org.uk and ill forward the message to you.
gosforth
A360 dynamode
I made a post to the ideas and suggestions board. PlusNet helpfully
gave me a link to linux drivers for the A360. I am just in the process of
downloading RedHat 9. I hope that it works.
Chris
A360 dynamode
I sometimes get that winzip error. Usually repackaging the files in the zip, and then reuploading them fixes it.
A360 dynamode
i look forward to your results ... and hope you can post the (sucesful!) details.
Thank you for answering!
A360 dynamode
Oh rigt - the original files you received from dynamod were like that - with the error? Otherwise i's up to you, scrimshire, to repackage them.
