A quick and hopefully easy question
Hi All
I have a "Mac" and am wondering if dowload a Windows Programme ie "exe" or "zip" and burn it to CD-R will it then work on a Windows machine or do "Mac's" do strange things to downloaded files that would prevent the saved software installing on a Windows XP machine?
Ian & Linda Jordan
The Mac should not alter any files you download so you should be able to write them to a CD and copy them to a PC. I assume a Mac written CD can actually be read on a PC?
Thanks peter
