8800 gtx tempatures help
got a 8800 gtx my idle temp is 64c running games 1 hour it 77c
is this bad or good
is there any good coolers to add to it
thanks
Doesn't sound good- what case do you have and what cooling do you use?
bikepump
ouch that's way too hot mate. My 7900GS runs at 46' steady through games. you must be seeing some graphical glitching with those sort of temps?Huh
The temp is useless without stating what processor you have and its clock speed.
Is it overclocked?
What was the tempo before you fitted the graphics card?
64C is high for any processor anyway.
You're getting confused, he is talking about his GPU temperature not his CPU temperature.
The temps you are seeing are a little high but nothing really to worry about, these 8800GTX's can go up to 125'C. The stock coolers apparently are designed very good, you might want to look at the airflow inside your case instead.
What case do you currently have? and how many fans?
Another option is to remove the cooler and reseat it with some Arctic Silver 5 thermal compound, although this may only see a few degree drop. The downside, it voids the warranty and can be a tricky job for 1st timers.
This looks like a damn fine cooler, made by Thermalright. You can add a 92mm fan or run it passively for silence.
http://www.thermalright.com/a_page/main_product_hr03_plus.htm
8800 gtx
case is a nzxt zero
motherboard fatalty AN9 32x
xp and vista duel boot
bfg 8800gtx oc 626 x 2000
amd2 5600 x2
hiper 730 r
2gb ocz ram 6400
2 x 150 raptors raid
2 x 160 samsung raid
i had a 7900 gt xfx it ran at 50 c
cpu temp is 29 c
sys is 34
pwm is 40
using abit guru and ntune if i set the fan control to 100% HuhHuhHuhHuhHuhHuhHuhHuh
That is a very nice system you have there. I suspect some of the extra heat in your system is caused by those beefy Raptors.
Thermalright cooler
If you are going for the cooler above i suppose 'installation' type 1 would be better because if you attach a fan on there it would also cool the memory at the same time.
jagger
Wow,
your graphics card is overclocked,in a crowded case,and is getting hot?Wow.
From the nZone
Try the driver 100.87 and use Rivatuner to make your card ALWAYS have its fan on a 100%.Should help the overheating
How about This thread on hot 8800's
How about a quote from
GAINWARD GmbH
Technical Support / RMA Dept.
Lochhamerstr. 29
D-82152 Martinsried
GERMANY
everything under 90C is OK.
You just posted to show off your computer specs,didn't you? Cheesy
8800 gtx tempatures
case is a nzxt zero
amd2 5600 x2
hiper 730 r
2gb ocz ram 6400
cpu temp is 26 c
sys is 29
pwm is 38
added a 120mm fan at the bottom of the case added cooler pci slot and romoved the front air filter my card is idle is 51c---- 69c full
GersFans
Re: 8800 gtx tempatures help
Yes its a little high for idle, but nothing too serious.
is this bad or good
Looks ok to me.
Yup, plenty. Googles your friend!
