32 or 64 bit
owlguard
32 or 64 bit
Hello,ive got an hp compaq business pc,thats running xp pro with,sp2 pack.Can anyone tell me if this is 32 or 64 bit machine.I was thinking about putting windows defender in and supplement it with adaware probably but ive never had anyone who can say,yes that pc is a 64 0r 32 bit machine 100%.My machines an hp compaq dx2200.
regards ray.
kenportree
32 or 64 bit
Hi, Ray, have you tried System Properties? Press the Windows and Pause/Break keys at the same time. System Properties should come up with the General Tab at the top, look for the computer spec towards the bottom of that tab. In my case it specifies "AMD Athlon(tm) 64 Processor"
Hope this helps.
Ken
32 or 64 bit
Right click on My Computer and select properties. It will tell you what processor you have. If it is not clear then post what it says.
If this is your PC then it uses a 32bit P4 or Celeron processor.
32 or 64 bit
Don't forget that it's entirely possible to run a 32-bit operating system on a 64-bit system, and even if you have a 64-bit processor your operating system is most likely still 32-bit (Windows XP 64-bit and Windows Vista 64-bit haven't really taken off as yet due to compatability issues).
owlguard
32 or 64 bit
Hello everyone and thanks for help,i believe my pc is indeed a 32 bit pc.Intel® Pentium® 4 processor 519K 3.06 GHz 1 MB L2 cache 533 MHz front side bus
This is what it says on the info page and by what you have said,it seems to be a 32 bit processor.
thanks to all and regards,ray.
