2nd Sata Harddrive
trexalan
2nd Sata Harddrive
Got a 160g sata hd with xp pro op (main internal hd)
just got 250g sata hd (internal) Just extra space.
Formatted it, went to properties 127g showing not 250g.
Found the rest of the missing space using disk management, formatted that section separately, but the 250g hd is split into two how would i create just one 250g hd?
2nd Sata Harddrive
Either delete both and create one large partition of purchase disc management software that is capable of merging or resizing partitions.
Acronis Disk Director Suite is probably cheapest although not recommended for large scale or advanced work.
trexalan
2nd Sata Harddrive
Nice 1 has easy has that. cheers
2nd Sata Harddrive
or, for the price of a blank cd rom, try http://gparted.sourceforge.net/livecd.php
