1394 Net Adapter
1394 Net Adapter
What is the 1394 Net Adapter that is showing as connected along side my LAN connection?
I cannot delete or disable.
Thanks.
1394 Net Adapter
Its your FireWire port.
Can can also be used with the correct adaptor as a simple way of networking two PC's.
Chilly
1394 Net Adapter
Ahh, nice one. Thanks.
phatty
1394 Net Adapter
I would recommend it for transfering Video (or other large files), when connecting my laptop to desktop with Firewire the transfer speeds are awesome.
Unfortunately I think it is limited to a connection of 15ft so it isnt the most practical solution for networking, but it sure is fast!
