why has my plusnet icons changed to BT
Hi was just visiting the bt site looking into installing another line then clicked off.....Went to my favourites for plusnet and their icon had changed to bt anyone else getting this or is it just me
decomplexity
Are you running ClairVoyant's Takeover by any chance?
Zen from May 17. PN Business account from 2004 - 2017
dunno but it hasnt changed back
Err ... I think the answer to that question is 'not yet' Smiley
Only a matter of time before www.plus.net redirects to BT Broadband.
decomplexity
...and I wonder what BT Retail would then do with PN's Tiscali LLU customers? Purely from a bums-on-seats (or rather ports-on-DSLAMs) point of view, it would make more sense for BTR to buy the struggling Tiscali UK.
csogilvie
What icon are you talking about?
Do you mean the one that appears next to your favourites? I assume you are using IE (by calling them Favourites) which leads me to believe that they are just being unreliable, as per usual (I've found Favicon's are a bit hit and miss ni most browsers!)
yes the ones next to my favourites i use IE7 and plusnet member centre and plusnet stable rate icon has changed to BT
decomplexity
Try getting the web page (e.g. PN member centre) on the screen, delete it in the Favourites list and then re-add it to the list. Then do the same for the other page.
Spooky or what :lol:
wished i had kept my mouth shut Cry
Yup ...
You just need to work on the lottery numbers now Smiley
i will need the lottery up to get my mac :lol:
eh..this is wierd http://www.plus.net/
Tongue :lol:
Fixes: 4
:roll:
