why are usenet speeds slow?
I'm download from external newsgroups at a whopping 100k and its off peak time.
howay plusnet what the hell is going on?
I've noticed lately that speeds have really started to drop. I've done speed tests and I'm getting around 5mbps, so are you throttling usenet?
right, I've just done 3 new speeds test and I'm not downloading anything at all while I'm doing it and this is the results.
205.40kbps
351.00kbps
599.70kbps
NOT GOOD ENOUGH
I've spoke to a friend on another exchange and he is experiencing the same issue.
I'm downloading something at the minute that is downloading at 6k a second.
can someone at plusnet please comment on this issue?
James
I'm imagine that this is related to the P2P/Torrent problem which I've documented in the other thread.
james, I can assure you it's not just a P2P/Torrent issue, look at my speed tests for today.
Date Speed Achieved (kbps)
08-09-2006 16:08:00 44
08-09-2006 16:07:15 100.7
08-09-2006 16:06:29 76.4
08-09-2006 13:29:46 599.7
08-09-2006 13:29:09 351.5
08-09-2006 13:27:25 205.4
08-09-2006 13:26:42 321.2
08-09-2006 11:15:32 5300.4
08-09-2006 11:14:46 5342
08-09-2006 11:14:25 3303
08-09-2006 11:13:53 5313.7
James
Are those all HTTP speed tests? Do BT Speedtests give similar results at the same times?
sorry its taken so long to reply, my internet is hardly usable, everything is taking ages to load.
it's done on the plusnet speed test, I've just tried adsl guide and it's showing similar results around 67kbps.
I'll try a bt test if I can get the page to load.
There is clearly a MAJOR issue here as a friend of mine is having exacly the same problem and he's no on LLU and he is on a different exchange.
I should be able to give you a report on the BT speed test around about 10:15am on the 8th October 2009.....that's when it's looking like it'll be complete.
I've just completed the BT test which is showing 25k per second
all seems well now
all seems well now
If the BT speed test is only showing 25K per second, then it's not PN at fault, but somewhere before that - possibly the exchange. Have you checked the VP capacity at your exchange whilst the slowness was there?
I'm on tiscali so I'm not sure checking the exchange status would show much would it?
How did you run the BT_speed test if you are on Tiscali LLU?
I typed in bt speed test in google, clicked the link and ran the test
