which package
albert
which package
I signed on to PlusNet about 18 months ago at £24.99 per month (which included a free modem). I see that the advert says 8Mb BB from £14.99 per month. Is it possible to change to a cheaper package or do I need to change to another ISP (I see that Sky are now offering free BB to their customers)?Huh
bobbygeorge
which package
SKY only offer their service through certain exchanges.
If you aint on one of the selected you wont recieve it
But , you are right they do offer free broadband if you are a full sky package subscriber.
you need to find out if you are in a sky enabled area ..
I ain't Cry
which package
Do yourself a favour and change to another ISP
I suggest Pipex
albert
which package
I ain't Cry
I ain't either :shock:
But they do offer a monthly package at £17.99 which would save me £8 per month unless there is some way of getting a cheaper package from PlusNet. I've been quite happy with my PN connection, but I think £24.99 is no longer competitive.
MrToast
which package
You certainly can 'regrade' to a different PN package. However, if the monthly cost of the new one is less they will levy a 'regrade charge' of (I think) £14.99.
Check out the product matrix. BB PAYG offers pretty much the same as Premier. If your usage is modest it may be cheaper. (Depending on 'modest' of course)
Fixes: 9
which package
How much is your total usage per month? How much of your usage could be scheduled for overnight?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
albert
which package
I do quite a lot of emails and I probably spend about an hour a day browsing the internet. I spend some time uploading stuff to my website but that is very limited.
I download the occasional software but that is only things like updates to my Norton Internet Security and Adobe reader programmes. I do listen to the radio on the Internet a bit and my daughter likes watching videos on you-tubes (perhaps half an hour per day on average.) Come to think of it she spends quite a bit of time on MSN messenger and similar programmes.
Fixes: 9
which package
Can you give us your actual figures from here for the last three months.
albert
which package
Billing Period usage in detail Nov 13 2006 - Dec 12 2006
Broadband EasyStart
Mon 13
Tue 14
Wed 15
Thu 16
Fri 17
Sat 18
Sun 19
Peak 36.39MB 36.54MB 159.86MB 125.68MB 155.64MB 320MB 387.03MB
Off-peak 105.56MB 23.74MB 28.2MB 4.06MB 52.46MB 166.08MB 138.52MB
Total 141.94MB 60.28MB 188.06MB 129.73MB 208.11MB 486.07MB 525.55MB
Peak usage: Off-peak usage: Total usage:
1.22GB 518.6MB 1.74GB
Mon 20
Tue 21
Wed 22
Thu 23
Fri 24
Sat 25
Sun 26
Peak 82.51MB 74.81MB 47.8MB 74.52MB 127.88MB 215.15MB 33.69MB
Off-peak 57.9MB 6.43MB 864.2KB 88.44MB 103.48MB 69.23MB 53.81MB
Total 140.41MB 81.24MB 48.67MB 162.96MB 231.37MB 284.38MB 87.5MB
656.36MB 380.15MB 1.04GB
Mon 27
Tue 28
Wed 29
Thu 30
Fri 01
Sat 02
Sun 03
Peak 0KB 25.27MB 113.9MB 2.02MB 12.18MB - -
Off-peak 67.26MB 543.81KB 106.4MB 57.22MB 9.15MB - -
Total 67.26MB 25.82MB 220.3MB 59.24MB 21.33MB - -
153.37MB 240.56MB 393.93MB
Mon 04
Tue 05
Wed 06
Thu 07
Fri 08
Sat 09
Sun 10
Peak - - - - - - -
Off-peak - - - - - - -
Total - - - - - - -
0KB 0KB 0KB
Mon 11
Tue 12
Peak - -
Off-peak - -
Total - -
0KB 0KB 0KB
Back to summary usage View Internet activities
Summary of usage in previous Billing Periods
13 Aug - 12 Sep
13 Sep - 12 Oct
13 Oct - 12 Nov
0GB 2GB 4GB 6GB 8GB
Billing Period Peak usage Off-peak usage Total usage
13 Aug - 12 Sep 4.34GB 3.22GB 7.56GB
13 Sep - 12 Oct 3.25GB 1.21GB 4.46GB
13 Oct - 12 Nov 5.25GB 2.08GB 7.32GB
Peak: 4pm - Midnight Off-peak: Midnight - 4pm
Fixes: 9
which package
Your usage would fit BB+ at £14.99, but as I am sure you will realise from all the posts in here, performance on BB+ isn't always that great!
I would suggest you consider PAYG which with 4GB per month included is £16.49 or with 6GB is £17.99. Midnight to 8am usage is totally free. If you go over your included allowance you pay £1.80 for each 2GB extra (or part thereof) used. PAYG is given higher priority than BB+ or Premier.
MrToast
which package
I wonder if you could avoid the regrade fee for a move to BB PAYG if you commit to enough additional bandwidth in teh first month to match you current subscription.
I don't know as I've not done it.....(and not read the rules so closely) but its worth asking if thats the way you want to go.
albert
which package
Thanks for the replies.
Three questions:
how much is the regrade fee to PAYG?
How long do you have to commit for?
Do I have to change hardware/software at my end?
Fixes: 9
which package
This page should answer most questions.
The trick agora suggested of initially opting for sufficient included GB to make the price just above your current fees used to work - I haven't seen any posts recently about it. But you are only talking about saving £14.99 so you may think it's not worth the bother.
albert
which package
Thanks, very helpful Smiley
