whens off/on peak then?
it seems to change so often, thought id check what is peak and what is off peak these days?
edit: im on the 30:1 2MB broadband connection.. dunno what its called.. broadband plus maybe
Peak-time is currently 8am till midnight.
This will be changing to 4pm till midnight sometime during March.
if your on 30:1 then you are on premier.
How much is the cost of the package you are on ?
Either way here are the peak times for both
BB+
8AM - Midnight peaktime ( with talk about it becoming 4PM - Midnight again in March )
Premier
4PM - Midnight ( SUP Allowance )
8AM - Midnight ( Clean to allowance. 20GB FTP/USENET/P2P ) ( This is moving back to 4PM - Midnight hopefully in March )
Hope this helps a little.
For Premier 2Mb, I thought the 30GB SUP peak allowance for all HTTP, P2P, FTP etc (everything) was 8am - midnight, not 4pm - midnight.
Also, like you said, there's 20GB FTP/P2P allowance was during peak hours 8am - midnight and 100GB total for everything peak and off-peak.
Am I confused too? Please put me right if I'm not.
from one of my other posts:
In general:
if you go over the 30 gig peak or 100gig anytime twice in three months you will be emailed to ask you to cut back
if you go over the 30gig peak and 100gig anytime twice in 6months or you get 3 warnings in 6months then you get peak time management for 1 month for p2p etc traffic only
if you go over the 30 gig peak and 150 gig anytime twice in 6months or you get put on management 3 times in 6months you get put on 24/7 management on all traffic
ALSO
for P2P / Usenet / FTP ONLY
You can download up to 20gig at full speed
the next 5 gig (20-25gig) at 512kbps (level 1)
the next 5 gig (25-30gig)at 256kbps (level 2)
the next 5 gig (30-35 gig) at 128kbps (level 3)
35+ at 64kbps (level 4)
SUP and Clean To details in a clear and concise way available from the UserGroup site here
Have a look at some of the other info pages. All in all its written for the customer by the customer and shoud be easier to wade through.
SUP is 4pm to midnight, P2P/Usenet/FTP traffic management peak is 8am to midnight. Once full automation of the traffic management is in place, P2P/Usenet/FTP peak will revert to 4pm to midnight.
This needs clarified.
The ability to deliver the clean to rates at full speed has been discussed elswere on these boards over the last few days.
Basically you will get the so called clean to allowances at the fastest speed possible, subject to the amount of bandwidth being available at the time.
The chances of getting it at full speed are virtually nil.
JonathanW
No, the SUP peak time is 4pm - midnight for everything, on the Premier package. And we will soon be changing the Clean To traffic management to run from 4pm - midnight as well.
I finally thought I was getting to grips with it, appears I was wrong, heh.
Thanks for the clarification Jon.
hi all
so when CLEAN and SUP are brought together 4pm to midnight do we get 20GB or 30GB to download P2P etc...
JonathanW
Clean To will remain at 20gb, for p2p/ftp/nntp, but SUP will remain at 30gb as that covers all traffic types.
Thx for a quick reply
I take it theres no set date atm is it liable to take affect this month or in march sometime. sooner the better i hope and then we can all settle down to the new system.
many thanks
JonathanW
Due to some further work that has had to be done, we're currently looking at getting this in place during March. Though at the moment I have no set date during the month.
thx for the replys peeps. i know when to run my dloads now Wink
