when no adsl at all...how to get plusnet to do something!!!
bluewhale
had no adsl all day, no sync with the exchange
on horrible 56kb modem now
how do i get plusnet to respond
open fault and called on phone to no avail
do they not prioritise problems
would have thought no adsl was high priority!
it'll now be another day as the problem is probly with the exchange and so they need to get bt on the case
very very annoying....where has the customer service goneHuh
used to be very good and quick!
Same problem. Unable to connect. ADSL status led flashing
Ring the customer support number to raise the problem or you could do it through the portal. All the best. Somebody please look into my problem as well, unable to connect/login.
bluewhale
wellover 24hours now without a response
and still no sync
wish i had a bt wholesale number....
Evil
bluewhale
just got this mail...
so plusnet have done something and cocked it up!!!
i've been on maxdsl for months now so it isn't that,
have i been LLU'ed without being notified??
and it's obviously screwed up...
CAN someone from plusnet please answer my questions!!!
As part of our commitment to providing the best value broadband experience, we have now successfully moved your broadband service to our alternative broadband network.
You should see no change in your service and you don't need to change any settings or your hardware, your broadband will simply continue to work as normal.
Thank you for your continued custom.
