what to ping/tracert
My connection is very 'laggy'. Slow pages and occasional timeouts on web sites, no particular site just in general.
Speedtest give consistent fast speeds, so I imagine the issue is in latency.
tracert to www.plus.net gives as follows:
C:\Documents and Settings\mark>tracert www.plus.net
Tracing route to portal.plus.net [212.159.8.137]
over a maximum of 30 hops:
1 1 ms 1 ms 1 ms . [192.168.2.1]
2 28 ms 19 ms 95 ms lo0-plusnet.ptn-ag1.plus.net [195.166.128.123]
3 355 ms 451 ms 632 ms ge0-0-0-103.ptn-gw2.plus.net [84.92.3.18]
4 82 ms 43 ms 26 ms ge0-0-0-23.pte-gw1.plus.net [212.159.4.25]
5 23 ms 33 ms * atm1-0.ptb-gw1.plus.net [212.159.1.89]
6 218 ms 73 ms 24 ms vlan18.pri.ptb-gw4.plus.net [195.166.129.130]
7 263 ms 383 ms 632 ms if2.ptb-al1.plus.net [195.166.129.39]
8 582 ms 379 ms 186 ms portal.plus.net [212.159.8.137]
Trace complete.
Any suggestions?
lol 3-4 instances there where plusnet are at major fault... some massive pings response times.
EDIT:
just done u mine for comparison
1 <1 ms <1 ms <1 ms 192.168.0.1
2 16 ms 15 ms 16 ms lo0-plusnet.ptn-ag1.plus.net [195.166.128.123]
3 17 ms 15 ms 16 ms ge0-0-0-103.ptn-gw2.plus.net [84.92.3.18]
4 16 ms 15 ms 16 ms ge0-0-0-23.pte-gw1.plus.net [212.159.4.25]
5 21 ms 21 ms 22 ms atm1-0.ptb-gw1.plus.net [212.159.1.89]
6 23 ms 21 ms 22 ms vlan18.pri.ptb-gw4.plus.net [195.166.129.130]
7 22 ms 22 ms 22 ms if2.ptb-al1.plus.net [195.166.129.39]
8 23 ms 21 ms 22 ms portal.plus.net [212.159.8.137]
Discostoo
C:\>tracert www.plus.net
1 * * * Request timed out.
2 238 ms 254 ms 453 ms lo0-plusnet.pth-ag3.plus.net [195.166.128.64]
3 179 ms 450 ms 337 ms ge0-0-0-403.pte-gw2.plus.net [84.92.4.2]
4 552 ms 536 ms 602 ms ge0-0-0-22.pte-gw1.plus.net [212.159.4.9]
5 170 ms 453 ms 304 ms atm1-0.ptb-gw1.plus.net [212.159.1.89]
6 380 ms 287 ms 52 ms vl4.sec.ptb-gw3.plus.net [195.166.129.227]
7 583 ms 476 ms 397 ms if2.ptb-al1.plus.net [195.166.129.39]
8 338 ms 450 ms 291 ms portal.plus.net [212.159.8.137]
:lol:
Trace complete.
ouch... and believe it or not im an unhappy customer on many levels including gaming ping... but i really feel for u guys!
Discostoo
well, its all getting funny now.
I think plusnet think i'm some sort of experiment, to see how long it takes before i snap.
"record DL speed in 3 weeks - 13kbps"
Thing is at 7:30 am the responses are fine and the connection feels like broadband (not trolling, just can't think how better to phrase it). This seems to consistently happen late afternoon (outside peak). I don't sit a watch my connection all day but have noticed checking mail etc before going to work is great. Check late afternoon and I start getting timeouts, not every day just too often to keep surfing fun.
coincidently - any downloads which have run fine all day drop to around 8 - 12k. I'm on premier, not a heavy downloader. Anything else I can do to try to track the problem down?
Ben_Brown
Have you tried any BT Speed Tests? This will determine if the problem you are experiencing is caused by exchange contention or another cause.
Just done the speedtest (bit of a faf that one).
result 1809 which is consistent with the speed test from the plusnet member area.
Mark
