what to make of these figures?
just setup the "proper ADSL router" Shockedops:
was wondering what to make of these figures.
Downstream Rate: 1152 Kbps
Upstream Rate: 288 Kbps
Downstream Margin: 31 db
Upstream Margin: 29 db
Downstream Line Attenuation: 18
Upstream Line Attenuation: 9
Downstream Transmit Power: 0
Upstream Transmit Power: 0
the_norris
Hi Andytj
They look very good. 2Meg easy. mostly likely 4Meg and i would say 'Should' get 8Meg.
The important parst are:
Look likes you are not to far the the exchange may be a few streets away.
Phil
I would say unlikely to get 8Mbs due to too high a line attenuation and too low a SNR
yep hehe i can shake my fist @ the exchange from here!!eheh
its only 3 streets away from me.
tbh i never expected to get 8mb thats just scary!!!
Cheesy
the_norris
Peter, you sure you are reading the values the right way round?
line attenuation is 18 (lower the better?)
SNR is 31 - (Higher the better?)
Or have i missed something here?
Phil
Nope, I misread it. Shockedops:
I now agree with your original reply.
i must learn to read posts properly
:mrgreen:
the_norris
lol Smiley
I had to read the OP details twice - normally people post the Line Atten' first then the SNR.
Phil
