what the hell is going on?
my speed are getting worse are plusnet have troubles?
http://www.adslguide.org.uk/tools/speedchart.asp?id=5601a2e1105797aee45f471d2ba
http://usertools.plus.net/tutorials/id/27
Following that tutorial will really tell you if it's PlusNet or BT.
egrog52
I'm having similar issues with speed:
http://www.adslguide.org.uk/tools/speedchart.asp?id=a66cdf51057a46510bb17e2584
Started around 1pm, I believe.
Following the linked tutorial, I got a poor speed from BT as well (I didn't take a screenshot, but I think it was around 140kbps).
Omegazerg, you should raise a ticket with PlusNet and they will take you through all the tests that you need to do, and then the fault will be sent to BT. If you're getting low speeds on the BT speed test that shows that it's BT that's slow, like your exchange.
If you're on 1mb/2mb, those speeds would be classed as unacceptable, and BT will one day probably get round to fixing it.
(On a side note, mine was fixed.. But it was just recently ADSL activated, so that's probably why they fixed it so soon).
