webmail help
webmail help
finally decided to give this a whirl.
set it up, but should it load up my emails from plus net? if my outlook at home has retreived them allready?
stupid question but one which is annoying me hehe
Plusnet Staff
Plusnet Staff
webmail help
If Outlook's already downloaded them then they won't appear in webmail unless you go into Outlook and set the "leave a copy of the messages on the sever" option. This will be in the advanced settings of you mail profile details.
I'd also suggest ticking the "delete after X days" if you enable this option otherwise it will just keep every single mail you receive from then on.
webmail help
thanks for the reply Smiley
