vmbu
m00nie
vmbu
anyone know how long the vmbu takes to update?
i logged on today and my usage was 9.78gb. today is my last day of the month so it resets tomorow.
without sounding like a cheapskate, i dont really want to be buying another 2gb at £1.80 and only use a few mb of it
either that or an early night with the old man..
yikes,could be the best £1.80 il ever spend
James
vmbu
It updates in accordance with the billing script, and generally resets about an hour after you are billed.
Any usage that you use tomorrow won't be counted towards this current months billing, if that's what you're insinuating.
m00nie
vmbu
sorry i wasnt to clear was i .
i was at 9.78gb when i logged on today. paid(well billed) up to 10gb
i wanted to try and monitor the last .22 as to not go over the 10gb else i would be paying for another 2gb with only till midnight to use it or lose it
i didnt know how long the vmbu took to update.
ive been online for 1hour 10 minutes now and todays usage is still showing as 0kb.
thanks
Zathras
vmbu
I think its a couple of hours behind
Fixes: 8
vmbu
I think it's the old man's lucky night! Wink
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
James
vmbu
It should be every 20 minutes. That's how often we get the information from BT, but every so often, these are dropped.
