vent problem
willhome
vent problem
is vent restricted?? i cannot connect to default port of 3784?
Plusnet Staff
Plusnet Staff
vent problem
Ventrilo? Shouldn't be any problems on the network, it's prioritised in the titanium queue which is the highest priority. Any firewall settings that could be blocking it?
vent problem
Reboot your router, failing that reboot your PC.
Turn off your software firewall temporarily to see if that is blocking it.
mthemis
vent problem
its actually running on my UNIX server. i've forwarded the port to my server and it responds to the ventrilo status page but my friend steve (willhome) cant connect :|
vent problem
Hi there.
Vent as in blog or ventrilo?
the blog isnt blocked and I am unaware of any issues with ventrilo at this time.
mthemis
vent problem
theres no software firewall on the UNIX machine and unfortunately rebooting the machine isnt an option for me. its ventrilo btw. tcp / udp port 3784.
vent problem
My advice was for your Windows PC so ask your friend to try it.
Mark64uk
vent problem
Used to have the same problem but with teamspeak. Had to go in a ticket and post a wirseshark dump, i wasnt told there was a reason but from this they found the problem and it worked ever since.
Mark
Fixes: 69
vent problem
Yep, if you can attach a short packet capture to a ticket then we can categorically tell you how the traffic is being prioritised. There have been problems with Ventrillo in the past however these have since been resolved AFAIK.
Kind Rgds,
Plusnet Products Team
