username
username
Having had the all clear to say that my friends account has been activated and having received the username and password required to enter into my router I tried but could not get a connection.
Three hours of fiddling I tried removing the dsl part of the username and it connected immediately is this normal?
username
Plusnet use several realms (the bit after the @) for broadband connections:
@plus.net & @plusdsl.net are the two most common ones used.
This will have been stated under Connection settings -> Connection details. If that does not match what you are using then you need to raise a question/ticket and get it investigated.
username
... then go on a round the world trip for 6 months and hopefully they'll be an answer when you get back Smiley
j/k
ID
username
weather you are joking or not, useless comments like that are degrading this forum. No wonder important posts get missed by staff with the amount of rubbish they have to sift thru. Sad
username
mhall please dont take offense i was merely trying to lighten the situation.
ID
username
fair enuff Smiley
Just seems like this place is getting like adsl guide and thats the last thing we want
username
hehehe i cant agree more Smiley
